Boost setup using 6mm offset chainring
Shredden
Knows his goats
Hey fellas,
My bike runs a boost setup currently, on a 12 speed shimano drivetrain and a 30t front ring with an 10-45 cassette. This is heaps of range for me but I do spend a fair bit of time in the largest and second largest rear cog.
On the other hand, I almost never use the smallest two cogs.
I’ve noticed the chain line is on a fair angle when climbing in the bigger cogs. If I understand correctly, my current boost chainring is offset by 3mm.
Has anyone had experience running a 6mm offset chainring on a boost bike, in order to make the chain line a bit better in the climbing gears (where most of the pedalling is done)?
Thanks
I did it with Shimano M8000 non-boost cranks on a boost frame (Ripmo V1). Driveside chainstay clearance was ridiculously tight (to the point it rubbed lightly if there was any grit on the chainring), but shifting was fine. A little easier in the bigger gears if anything, and the chain felt/sounded less distressed. Shimano 12sp may be a hair more finnicky though...
Just as alternative (or combined?) idea, you could try changing to a 28t chainring. That'll drop you a gear or so while climbing, and if you're barely using the smallest gear on the cassette it shouldn't effect that end of things too much.
The Duckmeister
Has a juicy midrange
If anything you probably want to go for a zero-offset (non-boost) ring to straighten the chainline to the inner sprockets.
LPG
likes thicc birds
I did see some people recommending the non Boost chainring/Cranks at some point due to chainline. I think it depends on your frame and setup. If you have a threaded bottom bracket you can do some fine adjustments with the BB spacers assuming you have them on your setup. You could move a spacer from the DS to the NDS to make an adjustment.
Mr Crudley
Glock in your sock
I have the same on the 5010 with 11 speed SLX/XT. It works fine and shifting is spot on. The spider on the cranks doesn't give any option to run a boost chaining so I am limited at 30T for now. It still gives me the gearing I'm happy to use so not a bit deal for now but I would need a new crankset if I wanted to run a 32T. I 'might' be able space out the driveside BB cup to sneak in a large chainring but could also make some new and interesting problems that I don't need :)
Maybe an oval chainring. The 30T is reputed to feel like a 28T + 32T depending on where you are in the pedal stroke.
creaky
XMAS Plumper
Absolutely. Non-boost chainrings give a better chainline on some frames, where there is enough chainstay clearance for the chainring. Not an option on many frames though.
