Wow. That must be a massive problem for them at the moment.There seems to be no stock of Sram 12 speed xo1 chains in Aust.
Yep just paid and it has gone through. Was there a previous problem getting Sram into Aust.?Are you sure you can ship SRAM to Australia from BikeINN ?
Try adding it and going to checkout.
Yep I could have used KMC etc but after a bit of research it was better off to replace the current xo1 with the same.Wow. That must be a massive problem for them at the moment.
Any alternative brands available and function with the SRAM gear e.g. KMC?
Major. Pretty much every OS chain blocked SRAM (which includes RS) and shimano.Was there a previous problem getting Sram into Aust.?
Yes, BikeINN with Australia selected shows no SRAM or Shimano.Yep just paid and it has gone through. Was there a previous problem getting Sram into Aust.?
I selected Aus and bought shimano…Yes, BikeINN with Australia selected shows no SRAM or Shimano.
If you select another country, SRAM and Shimano becomes available and it will let you add the item to your cart.
Just wondered if it lets you checkout with an Aussie address... which you said it does.
As soon as I select Australia, the Shimano and SRAM in my cart disappear but it still says there are items in there... invisible as above.I selected Aus and bought shimano…
There's a few sneaky overseas companies that still send geoblocked brands to Aus, the trick is to be a selfish chunt and keep it to yourselfFFS….if this lack of block gets noticed I’m blaming you lot
Wel….the levers are in my shed.As soon as I select Australia, the Shimano and SRAM in my cart disappear but it still says there are items in there... invisible as above.
Last time I ordered my SRAM gear from overseas I did check if they had Vittoria tyres for you..they didn’t so I kept quiet .There's a few sneaky overseas companies that still send geoblocked brands to Aus, the trick is to be a selfish chunt and keep it to yourself
Are you sure they are still thereWel….the levers are in my shed.
Yep. Phew.Are you sure they are still there
As the picture above, if I change the country to another European country, its lets me add blocked brands even with my official address still being in Australia.
Just wondered if it lets you checkout, which apparently it does.
