harmonix1234
Before I get into I it I will say that I am taking it to the shop for a qualified mech to look at.
However, does anyone have any good techniques for a home inspection?
Basic diagnostics tools?
I figured we should all have these skills in our bag as the world of biked becomes carbon dominated.
I found a crack on my carbon frame, but unsure if it's just the paint.
It's about as big as a 5 cent coin and shaped like a corn flake.
I can get my fingernail just under the thin layer of what seems like paint and it appears to go no deeper than the paint layer.
There has been no impact, it's on the side of the down tube a few inches from where it joins the head tube.
What I have used to determine it's OK is
a) The coin test. - Tap the area around it with a coin and listen to the tone. It should be a nice hollw resonating 'Donk'. Then tap the suspect area and listen to the sound. If you get a dull thud or change in sound then it's suss, but in this case it sounds just the same.
b) Press test. - With my thumb, press firmly on the suspect area, if there is a crack it may either depress slightly, or make a creaking noise. Neither of which happened.
c) Crack pattern. - The fact that it's a round shape only a fraction of a mm thick, and doesn't seem to go anywhere it makes me think that it is not a crack in the carbon as there is no linear seam that goes along any join of stress line, it's a really strong part of the frame and probably where the most carbon layers are.
d) Exactly the same thing happened on the chain stay. An area about the same size and shape flaked off, I got my fingernail under it and it just fell off like a scab. Underneath was smooth carbon. I got some 2000grit wet and dry and just smoothed off the dip between the painted edge and the carbon underneath and then hit it with a little clear nail polish and a year later it's just the same. Only a paint chip, but a large one.
Any suggestions for other diagnostic tricks I can do before I take it to lbs?
I'd post pics but not at home at the moment.
