Unfortunately I don't have any and my LBS is 2 hours awayFox float fluid
Isn't that ATF? Can I use a 15W-50 motor oil?Dexron III
Champion. Thanks Link.Repco and super cheap stock Permatex assembly lube. I’ve used Clevites assembly lube too, but you won’t get this in a retail site easily. The permatex stuff should be on the shelf at $15 a small bottle.
You could use motor oil but ATF sticks so well and has heaps of anti foaming additives (probably not an issue in this case).Unfortunately I don't have any and my LBS is 2 hours away
Good to know. I'm actually struggling to find assembly lube that's not a grease here, so ATF might have to be the back up.You could use motor oil but ATF sticks so well and has heaps of anti foaming additives (probably not an issue in this case).
Assembly lube is a good suggestion, I've got heaps of Torco and will try it next time.
It's the wonder lubricant, much under rated. We actually used it a few times as damper oil in a rally car because it's got such excellent high temp properties. Also a wonderful cutting fluid / lube for the lathe, drill, mill.Good to know. I'm actually struggling to find assembly lube that's not a grease here, so ATF might have to be the back up.
Gear oil around (75-90) is the best thing I've found, the assembly lube can be a bit sticky.Good to know. I'm actually struggling to find assembly lube that's not a grease here, so ATF might have to be the back up.
I'll see what they have. But yep, it looks like it's pretty fine based off the oil around the inside of the can. Either way I'm sure they'll have some option in either ATF or gear oil worse case.Gear oil around (75-90) is the best thing I've found, the assembly lube can be a bit sticky.
Is gear oil thinner?Type F ATF is thicker than the usual Dexron III if you are looking for a middle ground, but it's nothing like gear oil.
Perhaps some sort of jungle juice made of Dex and Torco.
Best thing you've found for what application? @DMan was asking for shock aircan oil in the OP. 75W-90 is thick as.Gear oil around (75-90) is the best thing I've found, the assembly lube can be a bit sticky.
I’ve thinned out slickolium with a bit more Esso mineral oil for one of my DT star ratchets. Few thousand km later, still good. Still safer to use the real dealSounds like this assembly lube would be ideal in freehubs as well?
Is the air can oil RS specs "Maxima Extra 15w50 suspension oil"?I needed to take my aircan off to take a positive spacer out and I'd like to add a bit of oil as recommended. I don't have any of the Sram oil so is there something else I can use? A really lightweight oil? It's only 5ml....
