birddog69
Wow! My shins hurt just looking at them.Extra long M4 grub screws for the "Shan-T-Macs".
They're only 7mm proud. 9mm screwed in.Wow! My shins hurt just looking at them.
I believe you; my shins not so much.They're only 7mm proud. 9mm screwed in.
The one I ordered has a strange schrader valve on it with a protruding jigger which lets all the air out too soon. I'm going to cut and shut the hose with an old pump and a barb fitting.Been using this digital shock air pressure pump/ guage for 3 months now no problems. Checked it air pressure measurements against 4 other guages and it all good.Used it to air up my rear shock to 225 psi no problems.
42.38AU $ 49% OFF|Pump High Pressure Suspension | Bike Suspension Pump 300 Psi | Shock Pump Bicycle Fork - Bicycle Pump - Aliexpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
Do you get a bit whoosh of air when unscrewing from the shock?Been using this digital shock air pressure pump/ guage for 3 months now no problems. Checked it air pressure measurements against 4 other guages and it all good.Used it to air up my rear shock to 225 psi no problems.
Spooky! Just bought this at lunchtime! Option 1. Should cover the 10mm/16mm I need for mezzer, and also has a bunch of others including 1/2” (12.7mm). While I got away with using prism shaped soft jaws, I couldn’t pass up a $20 version of actual clamp blocks.I've got a Ztto clampy thing on the water now, I've had 65 updates on the shipping status but it's still in China.
11.35AU $ 48% OFF|Universal Table Vise Bicycle | Bicycle Multifunction Tool | Bench Vise Clamp Jaw - Bicycle Rims - Aliexpress
No just abit of air . No lever on mine.Do you get a bit whoosh of air when unscrewing from the shock?
I have a similar pump hose fitting to @komdotkom and it seems to let a chunk of air out despite the little lever bit advertised as it wont.
YBN chain at 2510kms.
These arrived today, the clamps are ok but have a cast finish on the clamping faces not machined.Spooky! Just bought this at lunchtime! Option 1. Should cover the 10mm/16mm I need for mezzer, and also has a bunch of others including 1/2” (12.7mm). While I got away with using prism shaped soft jaws, I couldn’t pass up a $20 version of actual clamp blocks.
Road cycling and gravel biking is so MotoPiece Of Crap bike gear may or may not have set up shop at AliExpress. A solid effort either way you look at it.
https://www.aliexpress.com/store/912187451
How are these going @fjohn860Some recent purchases of mine.
Shoutai titanium pistons for shimano levers (I'd bought some "risk" pistons previously and they still leaked, so spent a bit more dosh on these "shoutai" ones). No leaks so far, and the lever feel is much better, even when bleeding the risk ones I'm pretty sure air was getting sucked past them as I was always getting air bubbles coming up into the cup.
AU $6.49 48%OFF | Bicycle Titanium Alloy Brake Disc Lever Piston Repair Part For SHIMANO DEORE XT M785 M8000 SLX M7000 Bike Parts
0.76AU $ 95% OFF|Titanium Alloy Brake Disc Lever Piston Repair Part | Shimano Xt Brake Lever Piston - Bicycle Brake - Aliexpress
Smarter Shopping, Better Living! Aliexpress.coma.aliexpress.com
The pistons themselves are performing perfectly.
You got to search for it on google, some Shimano retailer probably had a winge because they couldn't shaft a customer with exorbitant prices.Anyone got a reputable Ali-Shimano seller to recommend ? 007 looks to have shut up shop.
Looking an XT 12 long derailleur and shifter as they are mostly out of stock here or stupid pricing.
My fall back plan is LordGun at $200 for both then $49 shipping but I have another couple of items to throw in there too.
Cheers
Damn, they were pretty good.All the items seem to have been removed from the store,
I bought an XT crankset from these guys in August last year. https://www.aliexpress.com/store/1954042Anyone got a reputable Ali-Shimano seller to recommend ? 007 looks to have shut up shop.
