Haakon
has an accommodating arse
Umm... No... Sorry, must have been ebay!Got a link?
eBay/Ali account closed because of selling fakes ?Umm... No... Sorry, must have been ebay!
no, I just went through my past purchases list.eBay/Ali account closed because of selling fakes ?
I think it would be a no pivot idler.Is that a low pivot idler?
Chinese bikers are using SUMC chains, buy the best oneAnyone had any luck with the YBN SLA chains off Ali ?
Risk it all with the RRS kit bearing press!
Rrskit Bicycle Wheels/Hub Bearing Installation Press Set Bike Soft Tail Frame Turning Point Bearing Removal Installation Tool
53.03AU $ 65% OFF|Bearing Removal Tool Bicycle | Bike Bearing Removal Tool | Press Bearings Bicycles - Bicycle Repair Tools - Aliexpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
No, but interested to hear.Anyone bought shimano brake hoses from Aliexpress?
Just looking to lengthen on the DJ, brake is low end, but I'm just a bit short when I add the riser bar. Barely use the brake so quality doesnt really matter as long as works.
11.71AU $ |Shimano Hydraulic Brake Hose | Cycling Components Parts | Shimano M8000 Brake Kit - Bike - Aliexpress
I’d trust the attached banjo, and use my own shimano spares other end. Famous last words.Thou housing itself should be fine, just get shimano fittings
You can. @Plankosaurus had a link to some. Ali also sell them.It's always this fitting that is the hassle..... can you even buy that separately? install yourself? I thought you had to buy the hose with it installed.
Think easier to just try the one I had originally posted that comes with the connector already installed........ in theoryAU $4.09 30% Off | Bicycle Hydraulic Disc Brake Tubing Set Olive Head Connector Five-wire Body BH90 For SLX XT Cycling Brake Accessories
5.34AU $ |Stainless Brake Tubing|shimano Slx 4-piston Hydraulic Disc Brake Tubing Set - Stainless Steel
Smarter Shopping, Better Living! Aliexpress.coma.aliexpress.com
Agreed. Just sayin they're available.Think easier to just try the one I had originally posted that comes with the connector already installed........ in theory
Sorry @coarselanguagw, I didn't see this until now. I'll go check and report back soon.Hey Labcanary,
Can you measure the diameter of the threaded rod. This kit does not come with cups that could be used for bearing removal. However I'm wondering if the threaded rod would fit through my 1/2" sockets which would probably serve as an excellent stand in for proper cups.
