CNC machined from a block of steel with an alloy 46t, much like the ZTTO, Sram XG-1199 and whatnot cassettes. Ridiculously light, but holds up better than you'd expect being steel - shifting isn't quite as nice as Shimano/SRAM though. Options there if you want it I guess.I don’t know anything about garabunk (yes, I can’t help reading it as that) models at all. They popped up as options also. They’re aimed at the weight weenie market more? Sorry for my ignorance.
FFS....I love you hope, but this bites hard. I took the punt and ordered a ZTTO 9-46 and 9-42....faaaaaaaaaaaaaaaaaaaaarkCNC machined from a block of steel with an alloy 46t, much like the ZTTO, Sram XG-1199 and whatnot cassettes. Ridiculously light, but holds up better than you'd expect being steel - shifting isn't quite as nice as Shimano/SRAM though. Options there if you want it I guess.
Edit: Ahh yep that would be an issue then if a Hope driver. Looking at the ZTTO it's practically identical in design so that could run into issues too
you‘ve got my addressFFS....I love you hope, but this bites hard. I took the punt and ordered a ZTTO 9-46 and 9-46....faaaaaaaaaaaaaaaaaaaaark
No offers. I know what I’ve got.you‘ve got my address
that Is really annoying though.
Older e13 required a shim, not the later ones.Looking at the Hope driver, am a little confused on why it wouldn't work, I know the E13s require a shim because the body is slightly slimmer, but surely the length, splines, thread would have to be the same as other XD drivers?
Can lend you the Garbaruk if you want to have a play with it?
Oh didn’t know this. Do you know the size of the shim?Looking at the Hope driver, am a little confused on why it wouldn't work, I know the E13s require a shim because the body is slightly slimmer, but surely the length, splines, thread would have to be the same as other XD drivers?
I just had one more crack at resolving my e13. The plastic carrier always seemed to pull on a a bees dick too far after a ride and make the bottom 1/2 loose. I’ve tried packing it out with a bit of Teflon tape in the past...but that was only short term fix. Hunted high and low in the shed for a suitable sized O ring up stop it pulling on that little bit, to no avail....then accidentally stumbled across an old loom band in the sofa cushion.Oh didn’t know this. Do you know the size of the shim?
edit: just saw Mooreys post.
I resolved my e13 V1 issues too.I just had one more crack at resolving my e13. The plastic carrier always seemed to pull on a a bees dick too far after a ride and make the bottom 1/2 loose. I’ve tried packing it out with a bit of Teflon tape in the past...but that was only short term fix. Hunted high and low in the shed for a suitable sized O ring up stop it pulling on that little bit, to no avail....then accidentally stumbled across an old loom band in the sofa cushion.
Seems to fit just nice. Testing tonight. Wish me luck. If it works, I’ll transfer to Felix’s bike for the real test of the e13....
He swapped it with an idiot. Allegedly.I resolved my e13 V1 issues too.
I sold it to @Boom King who then had the good sense to sell it too.
Who woulda thunk loom bands had a real world use?I just had one more crack at resolving my e13. The plastic carrier always seemed to pull on a a bees dick too far after a ride and make the bottom 1/2 loose. I’ve tried packing it out with a bit of Teflon tape in the past...but that was only short term fix. Hunted high and low in the shed for a suitable sized O ring up stop it pulling on that little bit, to no avail....then accidentally stumbled across an old loom band in the sofa cushion.
I have been doing some gooGling and it’s the size of the end cap on Hope hubs that causes the issue. Thread here with details but from 2018, still reading through it to see if there has been a running change from Garbaruk, Interested to see what their response to your query is.Fark. Not compatible with Hope XD drivers?
I didn’t even check that with the ZTTO!
Looks like you need to machine a smidg off the end cap, if that post is right.I have been doing some gooGling and it’s the size of the end cap on Hope hubs that causes the issue. Thread here with details but from 2018, still reading through it to see if there has been a running change from Garbaruk, Interested to see what their response to your query is.
https://www.mtbr.com/threads/garbaruk-11-speed-cassettes.1056805/page-13
EDIT: Not compatible with Hope Pro 4 and I presume Pro 2 as well:
https://www.mtbr.com/threads/garbaruk-11-speed-cassettes.1056805/page-19#post-15193720
Saw that, pretty rough hack, but hey if it works, like someone else in the thread said spinning it down in a lathe would be a good solution. I guess I should have said it won’t work out of the box and requires some tweaks.Looks like you need to machine a smidg off the end cap, if that post is right.
Interesting. There’s thinner ones for the XD when you buy Hope adapters. The HG ones don’t fit and I run pretty much only XD now, so I’m a dab hand already at shaving a bit off on the linisher. Hopefully it’s just that. Many thanks @Flow-Rider and @shinyLooks like you need to machine a smidg off the end cap, if that post is right.
FWIW - The Hope Microspline driver is the same. Pull the adapter, remove/install cassette, push adapter back on. Slightly annoying, but easy to do and no specialised tools involved.I misspoke...the fatter ones fit XD, you just can’t fit/remove them with cassette fitted. Trim them down, and they fit inside lock ring....you can’t get your lock ring tool in properly with the adapter fitted, and you’d risk damaging the splines
Pro2 will be an absolute no-go. They have a big flat flange. Pro2 Evo are same as pro4. Both will either work....or not....I have been doing some gooGling and it’s the size of the end cap on Hope hubs that causes the issue. Thread here with details but from 2018, still reading through it to see if there has been a running change from Garbaruk, Interested to see what their response to your query is.
