Hi All,
This question has plagued me for sometime.
An Air shock or Fork, I know its generally better to have some travel left in reserve for those oh sh*t moments and you can tune the spring accordingly
A Coil shock - as it is linear, do coil shocks use the majority of travel all of the time (the bottom out bumper at the bottom of the shock shaft) regardless of how stiff the spring is (within reason)?, or should it typically operate like an air shock with the bumper just above the bottom.
I ask this as my coil shock uses all of the travel on trails (flow, rock gardens etc) but no harsh bottom out on drops. Just trying to asses whether I do need a stiffer spring or is this just normal for coil shock due to the linear nature of the coil.
Thanks in advance
Thanks in advance
