Or it might be of some use to someone who can use search properly and has Sun Ringle hubs after conversion info.Yep. Lets move this to pm now. Don't wanna hijack
Oh right. I have poodoodle on ignore. Can’t see that he’s posted here.I think that Clockworked was referring to his discussion with Poodle regarding 1.5" forks, I enjoy a good hijacking so stay or go, whatever makes you comfortable.
Interesting, my hubs are not straight pull and the 20mm end caps are only one piece... i.e. without the other washer/spacer shown in your first photo. I'll send a quick email to SunRingle and see if they can advise.
I've got similar on a DT Swiss hub, but the SunRingle doesn't have it, just locks in with an o-ring on the flange.Ps, it’s not a washer, it locks the adapter onto the hub.
As an aside, I didn't realise that feature removed all trace of the ignored, it must make for some rather disjointed conversations.Oh right. I have poodoodle on ignore. Can’t see that he’s posted here.
Meaning that it will probably be a bearing and adaptor change for me to go down to 15mm, anyway I'll wait until I here back from Ra.Right. I’ll wager it’s the 20mm version of the white 15mm I have that can’t convert to 20 coz of bearings.
Many more pros than consAs an aside, I didn't realise that feature removed all trace of the ignored, it must make for some rather disjointed conversations.
I don’t think so. Reckon a 15 adapter will slide in like hopes do.Meaning that it will probably be a bearing and adaptor change for me to go down to 15mm, anyway I'll wait until I here back from Ra.
Only if they made one, I would guess that if the Comps are marketed as a cheap OEM hub/wheelset then they may not have bothered with the tooling and inventory to make them convertible otherwise I would imagine that your hub would've just got the same bearings as mine just with a 15mm end cap, they look like the same hub shell.I don’t think so. Reckon a 15 adapter will slide in like hopes do.
Maybe. Does look the same.Only if they made one, I would guess that if the Comps are marketed as a cheap OEM hub/wheelset then they may not have bothered with the tooling and inventory to make them convertible otherwise I would imagine that your hub would've just got the same bearings as mine just with a 15mm end cap, they look like the same hub shell.
Sweet as. Hopefully if cokey wants to go 15, it’s s simpler matter. Thanks mate.Yeah my wheel is like your last pic @moorey with the white hub and red press-in adapters. Stuffed if I could get the right adapters for QR and yeah, the bearings are about 19mm internal so won't take a 20mm axle.
Interestingly the ID of my bearings is ~19.9mm and axle ~19.3mm, I reckon that they'd all be able to fit a 20mm with the right adaptors.Yeah my wheel is like your last pic moorey with the white hub and red press-in adapters. Stuffed if I could get the right adapters for QR and yeah, the bearings are about 19mm internal so won't take a 20mm axle.
