StInKy_boY
Item: 2015 Stumpjumper Expert Carbon EVO 650b MEDIUM
Item Condition: Excellent condition only done a months riding
Reason for selling: Bought it as a come back present to myself from breaking my back and neck, but after a few weeks riding i broke my collarbone so I'm off the bike again.
Price and price conditions: $4200 there $7600 new and I've only done 1 months riding.
Extra Info: Happy to Ship buyers pay postage.
There is a slight paint chip on the frame just behind the rear shock, and scuff or the rear stay BOTH ARE JUST COSMETIC.
FRAME: FACT 9m carbon, EVO 650b geometry, FACT IS construction, FACT carbon front triangle, M5 alloy rear triangle, tapered headtube, carbon PF30 BB, ISCG ’05, internal Command Post IR routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 150mm travel
REAR SHOCK: Custom FOX Float CTD Factory w/ AUTOSAG and Boost Valve, Kashima coating, Climb, Trail, Descend settings and rebound adjust, 194x51mm
FORK: RockShox Pike RC 650b, Solo Air spring, tapered alloy steerer, w/ compression, rebound adjust, 15mm thru-axle, 150mm travel
HEADSET: 1-1/8" and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
STEM: Specialized XC, 3D forged alloy, 4-bolt, 6-degree rise
HANDLEBARS: Specialized All-Mountain, low rise bar, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 31.8mm
GRIPS: Specialized Sip Grip, light lock-on
FRONT BRAKE: Shimano XT BR-M785, hydraulic disc, Ice Tech metallic pads, S/M: 180mm rotor, Others: 200mm
REAR BRAKE: Shimano XT BR-M785, hydraulic disc, Ice Tech metallic pads, S/M: 160mm rotor, Others: 180mm
BRAKE LEVERS: Shimano XT BL-M785, hydraulic, alloy lever
REAR DERAILLEUR: SRAM X01, 11-speed, carbon cage
SHIFT LEVERS: SRAM X01, 11-speed, trigger
CASSETTE: SRAM XG-1195, 11-speed, 10-42
CHAINS: RAM PC-X1, 11-speed
CRANKSET: Custom SRAM S-2200, carbon, PF30 spindle, 34T, 94mm BCD spider
BOTTOM BRACKET: SRAM, PF30, OS press-in bearings, sealed cartridge
RIMS: Roval Traverse 650b, alloy disc, 24mm wide, 27/32h
FRONT HUB: Roval Traverse 650b, 15/20mm thru-axle, 24h
REAR HUB: Roval Traverse 650b 142+, XX1 driver body, 12mm thru-axle, 32h
FRONT TIRE: Specialized Butcher Control, 60TPI, 2Bliss Ready, folding bead, 650bx2.3"
REAR TIRE: Specialized Slaughter Control, 60TPI, 2Bliss Ready, folding bead, 650bx2.3"
SADDLE: Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST: Command Post IR, 3-position height adjustable, remote lever (the new lever) 125mm post
Bike is stock as a rock, only thing I've done is turn it tubeless.
Any questions or offers just PM me.
BIKE DOESNT COME WITH PEDALS OR CAGE.
Pictures:
Pictures:
