hifiandmtb
Sphincter beanie
Don't think I've done a PYR thread on this bike, Google can't find it.
Anyway, bought this frame way back in 2012 from Kerry at Phantom as a special order...remembered I paid $3k for it. It's a large, and has had so many different builds over the years as evident in the photos below.
The build today is listed as follows:
Frame - 2012 Santa Crux Tallboy carbon, large, paint scheme is the best damn one SC has ever done IMO
Rear shock - Rockshox Monarch RL
Front shock/fork - Rockshox SID, XX internals (was originally Brain)
Handlebars - Enve XC, flat, 740mm
Stem - Ritchey 70mm
Headset - Chris King
Grips - Fabric Silicon Lockon
Saddle - WTB Silverado, Ti
Seatpost - Fox Transfer 125mm
Brake system - Shimano XT M785, metallic pads
Rotors - Shimano XT 180mm/160mm discs
Cranks - Shimano XT 170mm, 30t ring something something Snail(?)
Chain - Shimano XT
Pedals - Shimano XT
Front derailleur - Nah
Rear derailleur - Shimano Zee 10spd
Rear shifter - Shimano XTR 10spd
Cassette/Cog - Shimano XT 11-36t
Front hub - Specialized Roval SP
Rear hub - Specialized Roval SP w/ stupid 142+ spacing so have to lock out the smallest cog lest chain grind frame
Front rim - Specialized Roval, 23mm IW
Rear rim - Specialized Roval, 23mm IW
Spokes - DT DB SP, crazy expensive can only source from Specialized @ $5/each
Nipples - Were fucking stupid alloy now brass
Front Tyre - Maxxis Crossmark II, 29 x 2.25
Rear Tyre - Maxxis Crossmark II, 29 x 2.25
Tubes - Stans goop
Other bits - Complete Specialized SWAT system, headtube chain tool, two waterbottle cages, cage tool & storage container
Total weight - Dunno - maybe 10.5kg-11kg?
Cable routing was pretty crap from factory (doesn't cater for our brake setup) so organised as shown, sleeved inside heatshrink.
Retrofitting the dropper meant drilling the frame seatpost tube, was careful & drilled the area kinda recommended by SC.
This bike it a proper XC weapon, but twitchy as buggery in the rough stuff. IIRC it has a 71 degree HA. So, so much fun to ride.
Good luck prying it out of my hands, ever.
Photos from now:
Stem - Ritchey 70mm
Chain - Shimano XT
Pedals - Shimano XT
Tubes - Stans goop
Photos from now:
