camzh
Frame - 2011 Norco Range
Rear shock - 8.75"x2.75" Fox DHX RC4, now fitted with 2.8"x550lbs (I bought it with a 3.25"x400lbs)
Front fork - Fox TALAS 36 (2009?) 100,130,160mm adjust (I bought it with a 140-180mm TALAS)
Handlebars - Nukeproof Warhead 780mm ?
Stem - Transition Temple Lite
Headset - FSA probably
Grips - Lizard Skin lock on (was TLD)
Saddle - WTB Silverado
Seatpost - Norco
Front brake - Now: Juicy 3/180mm while waiting for something better (was Zee/200mm)
Rear brake - Now: Hayes 9/180mm while waiting for something better (was Elixr R/180mm then Zee/180mm)
Cranks - Truvativ Holzfeller
Chainguide - none ! Was E13, but now running RaceFace NW
Chain - Shimano
Pedals - Straightline
Rear derailleur - Shimano Zee 10sp (was X0 9sp)
Rear shifter - Shimano Zee 10sp (was X0 9sp)
Cassette - Shimano Deore 10sp 11-34T
Front hub - DT 350
Rear hub - DT350
Front rim - DT M480
Rear rim - Sun MTX 33 (was bent cracked and buckled DT M480)
Spokes - DT Champs in the rear, front is probably the same but not sure.
Nipples - Red DT alloy in the rear, not sure on the front, probably standard brass
Tyres - Maxxis High Roller
Tubes - Maxxis Welterweight
Total weight - 15.5kg (was more like 17kg when I 1st got it)
Story:
I bought this bike quiet a while ago, from RB, from a kid in Melb. It looks like he used it for some DH racing and sold it to upgrade to something a bit better suited.
As a result its got some pretty good signs of wear and tear. The rear wheel was flogged (cracked and bent) which I didn't know until I got it. But the kid was a champ and gave me some $$$ back to cover a new rim.
Here's how it looked in the brochure:
Mine looked like this:
I swapped out the front wheel to get it up and going:
I rode this for a while in this configuration.
Tried to take it for big jumps off little jumps:
Fell off it: (skip to 2:20 for the interesting stuff)
[video=youtube;vk3IYqXYjhA]http://www.youtube.com/watch?v=vk3IYqXYjhA[/video]
It wasn't until I bought a more gravity orientated frame that this changed.
I stole a fair few parts off this to get get my Blindside up and running (http://www.rotorburn.com/forums/showthread.php?288985-Transition-BlindSide)
So since then it was been sitting as a frame in the garage needing some love.
As parts for the Blindside rolled it, it freed up the parts to rebuild the Range.
This last weekend it finally saw it get rebuilt.
Seatpost - Norco
Chain - Shimano
Front hub - DT 350
Rear hub - DT350
Front rim - DT M480
Story:
