Dreggsy
Are any other people out there running a 1x9 setup?
I put mine together last night,
Blackspire 33t up front XT Crankset and XT 11/34 on the rear (still worn from last year)
I had absolutely no problems with this at all.
The only thing i am waiting on is the E-Thirteen XCX from DW to hit the country.
http://www.e13components.com/product_xcx.html
At the moment i using the front mech as low down as possible with a piece of cable for tension to keep it over the chainring,
it works and needs a tiny adjustment as when in the 11th I get a bit of rub.
I tested this at manly dam which isnt exactly smooth all the way around and had 0 issues with the chain coming off.
I do have a question though, where would YOU sit the chain-ring?
as in you can bolt it to either where the big ring used to be or where your middle chain-ring normally sits.
I have mine where the middle ring would normally go.
I'll post some pics of it soon
so you can kind of see what i've done.
there is an old brake cable running through a small piece of housing before going into an old xt ferrule.
this is to give the tension needed to hold the front mech in the correct position over the chain ring.
the front mech is as low as it can go on this frame due to the welds, i was a bit concerned about this, but so far it doesnt seem to be an issue, time will tell.
I would prefer to have the mech alot lower to stop any chain bounce.
